Old 27th December 2003, 17:13   #1
malcsmaesty
malcsmaesty's Avatar
Eletrical problem...
Hello all!!!
I have a small electrical problem with my TD
When i turn off the ignition,my battery light illuminates and stays on,even with the key removed.It doesn't illuminate at position III.
Am i right in thinking my alternator is bu ered?
thanks,
Malc.
CALM DOWN DEAR!,ITS A DIESEL!
2.0 CLUBMAN TD
smeggin'hell!!!
malcsmaesty is offline   Reply With Quote
Old 27th December 2003, 17:21   #2
H48HPE
1.3 LX
H48HPE's Avatar
definitely a broken rectifier on the alternator. disconnect your battery or it'll go flat because its discharging through the alternator.
answer is a new alternator or get the old one fixed by having the diodes replaced (presumably thats what it is)
Have you charged the battery whilst its still wired to the car recently? that can cause that particular problem.
andy
H48HPE is offline   Reply With Quote
Old 27th December 2003, 17:34   #3
Dave
Dave's Avatar
The rectifier and brushes are built into a small removable unit on the end of the alternator - you can swap this over for a new one... much cheaper than having the entire alternator re-conned.
Dave.
Dave is offline   Reply With Quote
Old 27th December 2003, 17:36   #4
malcsmaesty
Thanks for that Andy,i had a feeling thats what it was.Had a new battery this time last year,so i haven't had to charge it at all.
i have already taken the precaution of disconnecting the +ve feed,cheers mate.
malc.
2.0 CLUBMAN TD
smeggin'hell!!!
Old 27th December 2003, 17:38   #5
malcsmaesty
Dave.
Cheers Dave,any ideas on where i could purchase these parts? possibly a Rover dealer?
2.0 CLUBMAN TD
smeggin'hell!!!
Old 27th December 2003, 17:50   #6
H48HPE
1.3 LX
H48HPE's Avatar
Id get a whole unit from the scrap yard, and just swop the whole lot over, then Id hang onto the old one and get the parts for it when you get chance and then fix it as a spare. a second hand one will probably cost a tenner.
it should be a lucas A127 65 Amp alternator you need.
the part number for the rectifier from rover is BAU 5813 (should you choose to go down that path)
Andy
Old 27th December 2003, 17:57   #7
malcsmaesty
That's a good idea,will try scrappy on monday
cheers,Malc.
2.0 CLUBMAN TD
smeggin'hell!!!
Old 27th December 2003, 17:59   #8
tony
tony's Avatar
Send a message via MSN to tony
cheers,Malc.
while your there i have a list of things i want .....lol
Tony Hague
VX51AOD - 2001 ledbury maestro
tony is offline   Reply With Quote
Old 27th December 2003, 18:07   #9
malcsmaesty
send me a p.m then tony,then providing i've got big enough arms and bank balance.............. lol
2.0 CLUBMAN TD
smeggin'hell!!!
Old 28th December 2003, 11:20   #10
BIGLAD
BIGLAD's Avatar
Default Alternator
cheers,Malc.
Hi Malc,
I've sent you a PM
Thanks
Biglad
BIGLAD is offline   Reply With Quote
Old 28th December 2003, 11:32   #11
malcsmaesty
Hi Biglad,
have sent you a p.m,
thanks,
Malc
2.0 CLUBMAN TD
smeggin'hell!!!
