Old 20th March 2007, 13:17   #1
Default A series valve clearances
Anyone know what they should be?
I think that the exhausts are 0.014inch / ~0.35mm
Are the inlets the same too?
Can anyone confirm this or have a haynes manual to hand?
Old 20th March 2007, 13:51   #2
G Force
G Force's Avatar
Yes that is right 0.014in inlet + exhaust. apart from HLE which are 0.013in in + ex 1.3 Maestro Montego
G Force is offline   Reply With Quote
Old 20th March 2007, 14:08   #3
Thanks muchly. Got some to setup tonight and I've left the book at home!
Cheers again
Old 20th March 2007, 19:22   #4
bmcecosse
Inlets should be set to 12 thou - and exhausts to 15 thou, this to allow for increased expansion of the exhaust valve which obviously gets much hotter than the inlet!
bmcecosse is offline   Reply With Quote
Old 20th March 2007, 22:10   #5
Oh well I set both to 0.35mm and it sounds fine. They'll get checked in 500 miles anyway as they are bound to bed in a bit as all the valves have been lapped in.
