12th May 2006, 12:25
K-Seal Anyone?
Has anyone an opinion to offer on K-Seal please? It's rumoured to act like Radweld on a leaky head gasket............
BJ
12th May 2006, 13:12
I tried 'Barrs Seals', by the same people as 'Barrs Leaks' on my Triumph.....still had to change the head gasket!
12th May 2006, 17:35
Radweld and other similar products work fine on radiators and coolant hoses - they're not very aggressive environments, with relatively gentle changes in pressure and temperature as the engine warms up and cools down. In the old days, people used to pour eggs into their cars' header tanks to temporarily fix leaks.
The environment the head gasket works in is much different, with great changes of temperature and pressure many times a second.
Using Radweld etc isn't going to fix a leaky head gasket, sorry.
Rich Smith
M&MOC Treasurer
You can email me here
12th May 2006, 17:38
K-seal fixes cracked blocks... a friend of mine used it in his 306 TD and its been fine for a year. I doubt it would do anything for a head gasket but its better than Radweld.
13th May 2006, 10:43
Thanks everyone. the sales push at
http://www.kalimex.co.uk
is pretty impressive, and it seems East Sussex at last has made a contribution to the automotive industry! I think for £9.99 its worth a go, after all no-one wants to see a repeat of my "Diesel Head Woes" thread do they?
BJ
13th May 2006, 18:42
Worked on my panda, depends what engine it is and what sort of head gasket leak it is. If its an absolutely tiny one from a waterway it might work, did for me. No bigger than 0.5mm though I think, cant remember. Makes your coolant go brown though as well.
I didn't think it would work, but it suprised me.
Cars:
GHW 715X - 1982 Austin-Morris 95L (Mini van) 1.3 - garaged
E426 CHJ - 1987 Austin Metro 1.3 L Auto - was mint, now rusty
G967 SAP - 1990 Leyland Daf 400 2.0 - camper
T679 DOB - 1999 Rover 200 Vi 1.8 VVC - nippy
19th May 2006, 09:00
Well I poured it in and have done a couple of days of around town driving, so far so good. I suppose the real test wil be a long run. Have no idea if it is/was a cracked block or leaky gasket, but before using the additive the engine had "hydraulicked" so bad it would not turn without bumping the car in gear. (2 litre turbo diesel). Does prayer work?
BJ
19th May 2006, 12:56
A TD LX Estate I shared last year came with a blown head gasket - and got so bad that that just about hydraulically locked at the end. The face of the head was like swiss cheese, due to lack of antifreeze. A new head and gasket set sorted that, and we did a successful run on Staples2Naples2005.
Thing is, hydraulically locking an engine can cause funnies like bent connecting rods, especially if towing the car to start. Not especially recommended  .
Rich Smith
M&MOC Treasurer
19th May 2006, 20:33
Originally Posted by e692wtt
A TD LX Estate which we did a successful run on Staples2Naples2005.
that very same car is now up for sale if anybody fancys a cheep runabout test till dec , tax is just under 6 months. £225
Tony Hague
VX51AOD - 2001 ledbury maestro
30th October 2006, 13:15
K-seal does Work find it at http://www.ksealit.com
Hi im a montego man, had an estate for years apart from the odd electical problem on the lights it was great! I discovered k-seal some time ago put it in an old rover that we couldnt drive 3 miles in without overheating. We put it in and sat back and waited for it not to work but it DID! I was that amazed we tried it on a few other vehicles and then we set up a website selling it called http://www.ksealit.com and we have gone from strength to strength adding various tools and products and car and caravan covers. So We have k-seal to thank and we never stop being amazed at how well it works! It has to be worth a look for under £10, just read our testimonials if you are a sceptic because I like them was also a sceptic untill I tried it and it saved me £700! So visit http://www.ksealit.com:)
30th October 2006, 18:40
Just an add to this, my ex's MGF started leaking water from the front of the block shortly after a head gasket was fitted (head had gone soft from previous HGF) and one bottle of K-seal made it last 6 months until the HG went properly, so it does work as a short term measure and i was impressed that it held up for so long.
12th November 2006, 13:58
K-Seal - Does it work?
I've used it on several cars, including turbo-diesel.
I've written about it here...
http://kalimex.moonfruit.com
It has saved me a lot of money, and aggravation.
Andrew
27th March 2007, 21:05
K-seal is cheap and saved me a fortune
I shopped around and the best place to buy some K-seal is from
www.k-seal.co.uk they are great and they saved me a fortune. Got the maestro the extra boost it needed - well underated product, J
27th March 2007, 22:00
this k seal is the muts nuts done a headgasket on a k-series lump 2 weeks later it came back for oil in water header tank full of white gue
so we gave it a good flush until it was clear again put a bottle of k-seal in it filled with anti-freeze/water and we never had it come back
over than for its services
so buy it
it really works
20th December 2007, 19:21
#15
K SEAL
i have been repairing cars for 40 years,i bought a 1700 td astra 1997 mk 3 off a friend,bad starting from cold hydraulicking in the morning, this was the gm vauxhall engine,removed heater plugs next morning,number 3 sprayed out water when engine was turned over,never used anything before to stop this just used to do the gasket,give this stuff a try mate of mine said,K seal,£7.50 for a bottle,i put it in that afternoon,give it a 10 mile run,morning after started a1,so i took it on the motorway for a 20 mile run at 70+.that was 4 months ago and its still OK,if i had,nt tried it myself i would,nt belive it would work saved me a good few hours work and about £60 in bits,i dont work for K seal or anything to do with them this is an honest report by me,time served c&guilds mechanic,just can,t believe something can do this sort of repair,,
21st December 2007, 10:14
#16
Its only any good as a short term bodge. I wouldnt put the stuff anywhere near one of my cars. They dont call it dropping a turd in your coolant system for no reason.
If your headgasket goes the only way to fix it properly is to replace the gasket .. That stuff is awful to clean out, it coats everything with a horrible brown slime.
MGTurbo#261 - Sean
21st December 2007, 19:10
#17
k seal is not like a dog turd its a liquid think its got small pieces of copper in it
1991 mg maestro t16
1992 toyota hilux surf
1995 414sli
21st December 2007, 19:56
#18
Doh Sorry .. I misread and thought it was the barseal stuff ...
The info on the website sounds good, but anything like that is never a permanent solution to the problem. I put something similar in my LDV to stop a minor water leak from the HG and it worked, eventually it went completely though. But if it solves the problem on an old smoker to keep it going instead of major engine work it has a purpose.
MGTurbo#261 - Sean
21st December 2007, 20:04
#19
think they named it k seal just to temp repair the k series rover engine lol
1991 mg maestro t16
1995 414sli
22nd December 2007, 22:15
#20
 i used it in my maestroTDi but i still needed the head gasket doing-if the head gasket does go and causes air pressure build up in the rad-what will happen is the k seal will start to block up the veins in the rad-making the situation worse?
my head gasket ppl said it just blocks things up and advised to stay clear of such additives
0-60 in 8.2 hours 1/4mile in time for breakfast but the rust wins hands down
