Old 8th May 2006, 18:10   #1
Dean
Traffic Womble
Dean's Avatar
Default What Oil?
I know this subject has been raised before, but i'm wondering what oil to put in my 1.6 'S' series.
It's done 85K and It hasn't got any mayo at present. The car isn't going to be used daily.
Any suggestions?
Dean.
1993 2.0 Maestro DLX
1987 1.3 Metro Vanden Plas
1984 1.6 Maestro Vanden Plas
1982 1.3 MG Metro
1983 1.3 Metro Vanden Plas 500 #177 of 500
1984 1.3 Metro Vanden Plas Auto
1980 1.0 miniMetro Standard
1981 1.0 miniMetro HLE
1991 1.3 Metro Clubman L Auto
1982 1.3 miniMetro HLS
1997 (56) 1.1 Rover 100 Knightsbridge
1994 1.4 Rover Metro Cabriolet
1981 1.3 miniMetro S
1992 1.4 Rover Metro GS
1994 1.1 Rover 100 Kensington
Dean is offline   Reply With Quote
Old 8th May 2006, 20:09   #2
ChrisM
ChrisM's Avatar
Send a message via MSN to ChrisM Send a message via Skype™ to ChrisM
Duckham's Q 20W/50?
It must be Thursday. Never did get the hang of Thursdays.
Fleet Status:
P793 MKM - Rover 111 Knightsbridge (Running)
ChrisM is offline   Reply With Quote
Old 9th May 2006, 14:53   #3
Monty O
Tesco's.....
Monty O is offline   Reply With Quote
Old 9th May 2006, 16:54   #4
Chris Y
Membership Secretary
Chris Y's Avatar
It should really be 10/40. Assuming the engine's been treated well and the seals are all good, it won't need anything thicker.
As for brand, well they're all much of a muchness these days. Don't set too much store on a famous brand like Castrol, etc.
If you have a local motor factors, go in there and ask if they have any recommendations. If not, try getting some valvoline or Morris lubricants 10/40.
Don't buy the really cheap stuff (Tesco), it'll be full of wierd additives and will probably break down sooner than good oil, especially if the engine is subjected to high temperatures repeatedly.
Chris Y is online now   Reply With Quote
Old 10th May 2006, 07:59   #5
Monty O
...there's nothing wrong with Tesco oil!
Old 10th May 2006, 09:17   #6
MaestroTurbo
I agree. It's made by Castrol anyway, we use it in our non-turbo cars with no problems and its changed regularly.
MaestroTurbo is offline   Reply With Quote
Old 10th May 2006, 10:06   #7
Steve H
Originally Posted by ChrisM
Duckham's Q 20W/50?
Isn't Duckham's recommended by several people on this site as being particularly suitable because it doesn't exhibit so many problems with mayonnaise build-up.
T'other thing is I would have thought 10W oil a bit thin for a really worn engine (eg 80k miles plus). The gaps need a bit more thickness for bridging across to limit wear. 15W or even 20W would be better under these circumstances. All speculation, does this make sense?
Steve H
Steve H is offline   Reply With Quote
Old 10th May 2006, 11:32   #8
gothbob84
gothbob84's Avatar
Any idea of whom makes ASDA's elcheepo oil? i've not personally used it.... I use halfords oil fully synthetic on the hle and mg and vp and no problems with mayo build up....
Maestro 1.6 Vanden Plas in zircon blue - stored back on the road soon! - maybe not only has 2 wheels on at the mo!
Mk1 Austin Metro 1.0l in cashmere gold - 21k only
Austin Maestro - The 6K chocolate lime
gothbob84 is offline   Reply With Quote
Old 10th May 2006, 11:34   #9
MaestroTurbo
Steve H
All very well and good but the W is the cold thickness of the oil until a certain temperature. 20W 50 is great if your engine is shot but at 120 degrees it will be no thicker than a 15w 50 which lubricates better at start up, and if your engine isnt worn why make it worse?
80k plus doesnt always mean excess wear, my monty diesel still has 10w 40 oil at 192k and uses a litre every 3k so it will really depend on the circumstances.
A 15w 40, often cheaper than 10w 40 because it tends to be mineral is a good choice
Old 10th May 2006, 13:08   #10
e692wtt
e692wtt's Avatar
The 20w part of 20w/50 relates to its viscosity at a defined temperature (don't have the details to hand, am at work) and the 50 part refers to its viscosity at a higher defined temperature. The temperatures are defined in the oil testing prodedures.
In my Monty 1.6L (149k on the clock), a 20w/50 creates a lot less smoke than a 10w/40. In Fleagle my other 1.6L (26k on the clock) a Vauxhall Semi-Synthetic 10w/40 (it was a tenner at my local parts place, only reason I got it, though it just so happens it was intended for a Vectra V6 at one point) there is really no smoke at all.
There's a fair bit of 'mayo' though with the Vauxhall Oil, whereas with Duckhams Q 20w/50 there's no mayo at all all year round... the latter, brand-wise, is my oil of choice for minimising mayonnaise issues. I personally would use a 'branded' oil rather than a supermarket oil, but that's just my opinion. If you change your oil every few thousand miles then it would be fine to use any oil (wouldn't recommend the recycled stuff at £3 a gallon though!).
Rich Smith
M&MOC Treasurer
You can email me here
e692wtt is offline   Reply With Quote
Old 10th May 2006, 14:17   #11
Monty O
Ah, recycled oil at £3 a gallon? is that 10/40, 15/50 or 3.15pm
...from the chip shop?
Old 10th May 2006, 15:03   #12
MaestroTurbo
Correct, thats why i said 'cold' being the low temperature viscosity and the latter the 'hot' end of the viscosity test. 1.6's are known for being oil burners so in your 150k case its no wonder it uses less 20w 50 than 10w 40 because the engine is obviously well worn for whatever reason.
Old 10th May 2006, 15:04   #13
Ricky
Send a message via MSN to Ricky
Dont be silly, the 3:15pm from the chip shop goes in the fuel tank, actually come to think of it so does the recycled stuff at £2.76 a gallon (thats what it was last time I bought it for my Escort from Asda, which was years ago.....!):laugh:
Better late then never
1989 (88MY) MG Maestro 2.0i in Atlantic Blue - rusting in pieces!
1997 (Facelift) Citroen Xantia 1.9TD LX Estate in Admiral Blue - rattling to pieces!
1997 (Facelift) Rover 620ti in White Diamond - "Inherited", thanks Mum!
Ricky is offline   Reply With Quote
Old 11th May 2006, 11:01   #14
Simon
Simon's Avatar
I ran my replacement Gold Seal engine on GTX 10W 40 from day 1. Nearly 80,000 miles later no creamy gunge issues and the oil consumption is negligable really, despite a weep on the cam and crank oil seals.
Simon is offline   Reply With Quote
Old 11th May 2006, 13:26   #15
Monty O
Why do people have such an issue with mayo? My understanding is that this occurs when water becomes emulsified in the oil, such as leeking head gasket or lots of short runs when the engine doesn't warm up enough to get rid of moisture. Normal running should produce this even with the cheapest oils.
Old 11th May 2006, 17:22   #16
e692wtt
e692wtt's Avatar
It's mostly us paranoid owners of S-series Montegos pre-Mk II (when the Rover grille and flush rear lights as well as Roverised seats were introduced) and 1600 Maestros of the same vintage (but they weren't facelifted in the same way). At this stage, the 1600 breather system was totally changed, and the oil filler pipe deleted and a filler point on the cam cover fitted instead. The cut off is when the cars were certified as being able to use Unleaded petrol.
(I think) it applies to all O-series cars too. It's mostly owners of 1600cc cars than complain though .
Essentially, if the engine has an oil filler pipe at the front of the engine bay, it will suffer to some degree.
The mayo blocks up the breather system and the crankcase fumes then pressurise the block. Oil then blows past various oil seals onto things like the cambelt and clutch - which is a lot more hassle than keeping the ventilation system clean. It's a minor inconvenience, to be honest , as weekly checks are enough to keep on top of the problem (if it arises).
It can be a tangible problem though. I call it 'character' :laugh: .
Rich Smith
M&MOC Treasurer
