Old 16th April 2006, 20:03   #1
boveybob
Default Soggy carpets
Decided to Spring clean my Maestro Advantage. On taking the rear carpet out I found some water in the footwells particularly on nearside. This has caused a bit of rust to the rear edge of the floor pan that I will need to get sorted - a stitch just in time! There are no obvious leaks - has anybody any ideas where its coming from?
Many thanks
boveybob
boveybob is offline   Reply With Quote
Old 17th April 2006, 12:43   #2
MG MAL
Best to check door seals and window seals, as they become squashed(doors) and the window ones become hard/brittle over time and can let water in.
Also check sunroof seal, and sunroof drain points (if fitted).
HTH
Mal.
MG MAL is offline   Reply With Quote
