Hi!
Finally I get the adjustments of my LPG installation to where I want them: The problem up to now was rather high consumption in and around town (I got up to 260kms/160miles from my 31l tank). So I took some time to fiddle with the adjustments (lean out until car starts to loose performance or show reluctancy when picking up). The first go delivered me 300kms/190miles on about 28l in and around town - very satisfactory for LPG. But on the Autobahn it was too lean, the car was far from being happy at rpm above 3000. So I enriched the mixture bit by bit until I found it cruising OK: Result: 380kms/240miles with just 27 litres (for just under 10 quid!! ). I have not been driving quick (around 70-75mph all the time, mostly on cruise control), but I am pleased. LPG will usually get consumption figures about 10-20% worse then petrol, so I think I can be happy with the results now. The car is still not pulling as good as it was before at faster speeds, but the engine is not complaining, so it seems I am close to the 'lean' spot, where the engine has slightly less power then possible, but is most economical.
There's also still an unresolved problem, probably someone of you may have the answer: When running on LPG the feather sprung needle of the SU carb will wear out the jet quite quickly (several 100km will see the mixture to start getting rich, several 2000-3000 will see a carb that is nearly not adjustable). I tried to fix the needle in the piston, so that it doesn't slide along one side of the jet all the time, but I don't seem to have got it fitted stiff enough, since the jet still wore out further. I considered thinking about something like screwing the jet down as far as possible while not using petrol or fitting a modified cap, that has something that can be used to lift the piston instead of the damper. I even thought about changing to an old HS6 carb, which has a fixed needle. Any ideas? Basically I do not run the car on petrol at all, but being a bit perfectionist I want it to run perfect, when it should do. Ideally by just flicking the switch from LPG to Petrol...
(the last 12 Months or 11k miles have seen me using less then 1 tank full of petrol - so I am not really desperate to find a solution).
Regards,
Alexander
Regards,
Alexander
