This is the reason you should change your antifreeze regularly. Otherwise especially if you own a diesel this happens:
Why you should change your antifreeze regularly
Last edited by E_T_V; 26th March 2005, 22:15.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
www.roverdiesel.co.uk - My Rover Diesel SiteTags: None
The car and engine belong to a group of our club members who are hoping to complete the staples to naples rally in it later this year.
Honing marks most definatly are a good thing. A honing tool is used when the engine is first built to roughen the cylinder walls up so that the piston rings can bed in properly. (I know it seems silly to want the cylnder walls to be slightly rough but there are proper scientific reasons for it). As you can see the criss cross pattern is still visable meaning that the engine has had little or no wear to it as the honing marks wear away with age as the piston and rings slowly wear away at them (wear from the piston would be in the form of vertical scratches rather than the criss cross ones observed. This engine has I believe been re-bored/resleeved and fitted with oversize pistons fairly recently by the look of it. Which is obviously a good thing It is a shame the same attention wasn't paid to the cylinder head but as you can see that is on the mend now.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
yep
my recent 1mm rebore to my old perkins has glazed piston walls and this has caused me to loose loadsa oil burnt
The guys are going to hone the piston walls as under guarantee0-60 in 8.2 hours 1/4mile in time for breakfast but the rust wins hands down
