Various Maestro Parts
  • [For Sale] Various Maestro Parts
    For sale Various Maestro parts all located in York new and secondhand. Offers please and ALL panels are for metal bumpers unless stated
    New Front panel
    New nsf Van wing
    2 pair front wings Metal bumper new
    Front and rear metal bumper corners, secondhand scuffed but not cracked
    Good secondhand red tailgate
    Secondhand silver bonnet
    Full 1.3 exhaust, new
    Seondhand fuel tank
    1.3 Rad New
    Pair of headlights New
    2 x 1.3 Starter motors recon
    Secondhand rear panel, very minimal surface rust
    Pair secondhand A posts, from roof to chassis
    Rear inner and outer wing panels, metal bumper, crusty around the arch part
    Set of 4 doors, 2 have surface only, one repaired but needs filling and other is crusty
    All these new for 1.3 engine cars
    Gaiters
    Flasher lens
    Ball joints
    Crank gasket gearbox end
    First motion seals
    diff seals
    GRK2007 Rear wheel cylinder kits
    Rear brake shoes
    Gearchange short link
    Interior mirror
    Courtesy light
    Tailgate strut ball pins
    Grill locating grommets
    Rear shelf rubbers
    Door handles
    Fuel filler lock and keys
    Tailgate struts
    Brake cables
    Pedal rubbers
    Brake pads
    Ball 4406 RH brake indicator
    Brake caliper pins
    Front caliper seal kit
    Rear wheel cylinders
      More
      Throttle cable
      Steering column intermediate shaft
      Track rod ends
      CV Joint EDG236
      CV Joint BVGK200
      CV Drive flange rubber cores ADU6622
      Front and rear wheel bearings
      Engine Mountings CRC5555 CRC564 NAM2118
      Wiper arms
      Rear light gaskets
      Vacumn pipe servo
      Maestro badge
      TAM1305 Vac pipe T piece
      Heater motor ADU8718
      SU needle and seat
      Gearbox diff seal BAL2886
      Transvers rod gear linkage UKN10042
      Rad Fan
      Rear shocks
      Thermostat housing top TAM1157
      Oil filters
      Air filters
      Speedo cable
        more
        gearbox change links socket ends
        Washer pumps
        Vac pipe distibuter elbows
        Exhaust gaskets
        Tailgate lock and keys
        Brown window winder handle
        Sump front seal TAM1171
        And more small parts
        all located in York so pm or ring me
          Some more found today
          2 shock absorbers
          re-con 5 speed gearbox
          new battery tray
            2 shock absorbers
            new battery tray
            how much for 5 speed gear box
              "Flasher lens"- is that a Maestro indicator? If so, which side and how much posted
              Thanks
                Don't suppose you have a thermostat housing for Perkins Prima?
