Old 21st June 2003, 09:29   #1
acerocks
Default Philips R861 Cassette Player Keycode
Hello All,
I have a Philips R861 cassette player which i wish to install in my Maestro, but have not instructions with it. I have the keycode number which is 7901 but the number keys on the stereo are 1 to 5, can anyone tell me how i enter a number higher than 5 or enter the number 0. Any help anyone could give me would be very much appreciated.
Thanks in advance.
Martin
acerocks is offline   Reply With Quote
Old 21st June 2003, 09:52   #2
malcsmaesty
malcsmaesty's Avatar
Hello acerocks!
most coded stereos follow the same sort of code imput,try this
1.switch on,code symbol appears,press pre set button 1
2.press one of the tuning buttons < > to enter 1st digit of code.
3.press pre set button 1 to store 1st digit
4. follow steps 2-3 to enter rest of code
5.when all 4 digits have been stored you should hear a two tone beep to let you know the code has been entered correctly.
hope this helps!!!!
malcsmaesty is offline   Reply With Quote
Old 21st June 2003, 12:23   #3
topgear
topgear's Avatar
works for me! :-)
--- Top gear, top thrills! ---
topgear is offline   Reply With Quote
Old 21st June 2003, 12:43   #4
D87 SMW
Montego Convert
D87 SMW's Avatar
Isn't it the Philips R681 not 861? B.t.w I am still looking for a Philips R570 or R670, anyone got one on offer?
Steve Worsley - The Post-Cowley Maestro Register
BL Tat:
D87 SMW - 1986 Austin Montego 1.6 HL - Running
N207 ENE - 1996 Rodacar Maestro 1.3 LHD - Stored
W367 LNA - 2000 Rover 75 1.8 Classic SE - Running
D87 SMW is offline   Reply With Quote
Old 22nd June 2003, 20:41   #5
matthewsemple
MG 'M' Group
matthewsemple's Avatar
Send a message via MSN to matthewsemple
Phillips R681
It is a Phillips R681. This model was fitted to the MG Maestro Turbo, MG Montego 2.0i and MG Montego Turbo and some Rover 800s between 1989 and 1991 (ish)
Click the image to open in full size.
Malcolm's instructions also apply to the R570 (fitted to 1.3 and 1.6 Maestros and Montegos) and R670 (MG Maestro 2.0i) There is also a Phillips R361 that has manual tuniing and was fitted to low spec models and Minis This doesn't have a code.
You can de-activate the code by:
1. Press up tuning button ^ whilst turning on stereo
2. Enter code
Matthew Semple
The MG 'M' Group
matthewsemple is offline   Reply With Quote
