Old 16th April 2009, 21:52   #1
MG Maestro Van
MG Maestro Van's Avatar
Default Engine Replaced but no spark or fule
I have just replaced the engine in my turbo van. The first problem has been The replace ment has obviously been an early montego turbo engine the oil pump is a diferent construction to the outher engine in the van, the oil pump is at the front of the engine and slung under the botom pulley. Also has shalower groves in the pulleys for the timining belt also only has one oil feed from the oil pump for the turbo but no oil presure switch. I know that this would cut out the fule pump but would it cut out the spark from the coil to as I have no spark at the coil. I suspect this could be a dodgey crank sensor but did they change the fly wheel at all I am new to maestros/Montego turbo's so can any one help?
MG Maestro Van is offline   Reply With Quote
Old 17th April 2009, 06:51   #2
Russ
Stuck in the 80s
Russ's Avatar
I shouldnt cut out the ignition supply ,but as your van is a modified vehicle does it have the full turbo car wiring loom?
I take you realise the cam belts are not interchangable.
Russ is offline   Reply With Quote
