Old 4th April 2009, 21:54   #1
emanresu
Banned
Default Maessro woes
Hi. this is my first post so be nice
Ive got some worries about my Maestro.So I'll start from the beginning.
The front wheel bearing on a recent trip to the continent decided to become very noisy. now, it's making a rubbing noise going round left hand corners. tried wiggling the wheels whilst on the ground and it seems theres a lot of play in the drivers side one.
is this easy to change?
Second, after changing the air filter recently (The old one was black and stuck to the case) the power seems to be down. is this because the mixture would have been weakened off? It goes well on full throttle and stuff, but pickup from standstill can be sluggish if you don't give it enough gas. Also, seems to surge slightly.
Third, my negative battery terminal keeps popping off. don't know the reason, but it causes everything to dim. it's as tight as i can get it.
fourth, when i fill the tank to the top, some petrol leaks out. I can get about 43-44 litres in before this happens. any ideas?
Thanks.
emanresu is offline   Reply With Quote
Old 5th April 2009, 10:31   #2
henocsr
1, Wheel bearing, not to differcult to change on early models as they are of an old design simular to the rear bearings. From 1986 on wards one piece cassette bearings are fitted which must be pressed in using a press. If you have been driving around with a failed bearing for a time now it may need a new flange as well. (easy to find as they are the same as MGF as are the wheel bearings)
2, Airfilter, if the air filter was blocked like that and the carb has been set with that air filter then yes the mixture would lean off now youhave good airflow. Best thing to do is fit new plugs as well and get the carb set up, or fuel injection system if yours is an EFI.
3, Battery terminal, you can buy new terminals from a good motorfactors and halfords as well. Easy job to sort
4, Fuel leakage, as for fuel leakage you will have to fill the tank and see where it leaks, could be leaking from the top of the seal on the level gauge (which is at the front of the fuel tank) If its the tank there are lots of new 1.3 and 1.6 fuel tanks out there on ebay. EFI and turbo models are differnt tanks which are expensive as they contane swil pots makeing to tank more the produce
2001 Rover 45 1.8 impression s saloon
1997 Rover 623 GSI auto
henocsr is offline   Reply With Quote
Old 5th April 2009, 12:06   #3
Ricky
Send a message via MSN to Ricky
You have got the correct type of battery fitted, I presume? I *think* I'm right in saying that all petrol Maestros and Montegos use an 063 type battery, this doesn't just dictate the size of the battery itself, it also sets a standard for the size of the terminals on the battery itself - I only mention this as I remember my dear father having a very similar problem with a car after he bought a new battery for it, he bought the cheapest battery he could get his hands on, which was an 038, which has posts that are much smaller than the 063 he should have got - not only did it not fit into the tray and bolt down (bungee cord battery clamp anyone?!?!), but the terminals kept working themselves loose over time with much the same effect you describe, though it wasn't uncommon for his to pop off as he was going along.....
Better late then never
1989 (88MY) MG Maestro 2.0i in Atlantic Blue - rusting in pieces!
1997 (Facelift) Citroen Xantia 1.9TD LX Estate in Admiral Blue - rattling to pieces!
1997 (Facelift) Rover 620ti in White Diamond - "Inherited", thanks Mum!
Ricky is offline   Reply With Quote
Old 5th April 2009, 13:37   #4
emanresu
Banned
Hi there, thank you for your reply.
The car is a 1992 Maestro 1.3L.
The wheel bearings I'm told are the newer type. I've been given a new hub from a Montego Turbo D. Will fitting this solve the problem?
I thought the mixture may have been leaned off. Thanks for confirming that may be the case. I will get the car set up soon.
The battery was fine until I disturbed the terminals when I removed them a few weeks ago to change the front bumper.
I believe the tank after a recent fill up, is leaking from the filler neck.
I believe the battery is the correct sort, but it looks to be the original battery. So perhaps the terminals have worn down? I don't know. I was going to wrap some tin foil around the posts and then tighten the clamps around them...?
Old 6th April 2009, 12:18   #5
Jumturbo
Jumturbo's Avatar
Have you got the whole hub carrier with bearing? If it is the later type it should be the same as your Maestro. I just changed my hub carriers ( albeit a Montego) with bearings already fitted. ( luckily I bought them new a few years back). Much easier job than going getting the bearings pressed out and in. If you have not damaged the old hub, you can get a new bearing fitted at some stage, ready for next time!
The fuel leak could be a corroded filler pipe or corroded vent pipe. My monty's vent pipe had corroded away where it connects to the filler pipe near the top. I need to locate a new filler pipe really, but for now have re-piped it with steel fuel pipe and a proprietry stop leak compound which is resistant to petrol. It could also be the rubber connector between fuel tank and filler pipe. The clips can rust away here or the rubber split.
'56' MG ZTT160 Silver
'05' MG ZR115TDSE Red (Hers)
'W' TR7V8 Will be Black
Jumturbo is offline   Reply With Quote
Old 15th April 2009, 20:19   #6
emanresu
Banned
hi guys. just got the car back from having the bearing done.
brake pads now need to be replaced as they've just gone through to the pads as i've pulled into my driveway.
the car is driving nicely. now driving slightly left (as opposed to right!).
how much are brake pads?
chris.
Old 15th April 2009, 20:41   #7
Depends on the brand, but the pads themselves cost anywhere from £10 to £40.
Fitting takes about 30mins to an hour.
Old 16th April 2009, 15:25   #8
emanresu
Banned
£11 from wilco. cheapy brand, but all seems well now. I can stop in a straight line. very uneven brake wear though, needs looking into further i think
Old 17th April 2009, 11:48   #9
G Force
G Force's Avatar
If the old pads were tight to remove from the carrier at all, as long as you cleaned everything up ok and used anti seize compound then you may have gone a fair way to fixing the problem already. If not other things to consider are.
Pads gone down to metal previously and scored the discs.
Calliper slide pins sticking. or badly worn and binding.
Callper pistons sticking.
Flexi brake hoses faulty holding brakes on.
G Force is offline   Reply With Quote
Old 17th April 2009, 13:33   #10
steve smith
steve smith's Avatar
Send a message via MSN to steve smith Send a message via Yahoo to steve smith Send a message via Skype™ to steve smith
how would a flexi hose become faulty there isnt anythign on them to become faulty...
E169 HAN Austin montego 1.6 L (IN USE) power steering fitted
steve smith is offline   Reply With Quote
Old 17th April 2009, 20:24   #11
They can collapse internally leading to either fluid not getting to the caliper, or in come cases not get back out hence it holds the pressure in the caliper causing the brake on that wheel to drag.
Old 17th April 2009, 21:36   #12
emanresu
Banned
will replace all of the hoses then. any idea on cost?
Old 17th April 2009, 21:43   #13
Usually they don't give problems, but roughly speaking they are about a tenner a corner.
