How to re-cover a seat
  • How to re-cover a seat
    As the drivers seat in my Turbo is showing its age I recovered the base and seat back. This is what you do from start to finish.
    Starting at the front. Push the seat right back and remove the front 2 bolts. Then push the seat forward to memove the rear bolts. Retain the washers
    Put the seat onto a sturdy platform.
    Remove the headrest by pressing the sides of the retaining tubes
    Pull off the seat reclining knob and remove the screw and side covers from both sides
    Remove the 2 bolts either side
      Remove the long clip holding the the back of the seat to the base
      Seperate the back from the base
      Remove the seat slider by undoing the 4 bolts. Retain the bolts and washers
        Remove the four long clips holing each side of the cover
        Remove the small clips holding the excess material and retain
        Turn the base over and remove the sides of the base cover
        Turn over and remove the front and rear clips each side from the mesh surround
        Remove the four wire clips (two each side) from the centre of the mesh surround and retain
        Remove the long flat
        Turn over and remove the cover
        Last picture shows the clips you need to retain
          Old wornout base
          Mesh and surround
          Replacement base
          Replacement base back on with cover
          Much better
          To put back together is the reverse of stripping it down. Remember to line up the holes on the cover
            Now the seat back
            Remover the long clip holding the cover and pull back a little to see the other clip
            Remove the clip
            Slowly push remover the cover while pushing down on the foam until you see two clips either side of the foam
              Turn over and remove the two long wire clips
              Push the cover up to the next point which is the top of the long wire clips
              Turn over and remove the clips by twisting and pushing noting the position on the mesh
                Slide the cover up and over the top
                You will now need to remove the two headrest tubes. (second pic) You may find it easy but this it what I had to do
                Remove the springs from the mesh and surround and retain. The front and back remove easily but the middle spring is tensioned. If you dont have a hook use a screwdiver
                Remove the two clips and retain. Ease of the foam from the surround
                You can now separate the foam/mesh enough to get a screwdriver on the tube retaining parts.
                Squash them inwards
                  And push out
                  Old seat foam
                  The two headrest tubes. Note the retaining parts that need to be opened out. Also note the channel as the tubes need to be put back correctly. There is a dot on the top of each and this needs to be facing forward.
                  To recover is the reversal starting with the mesh
                  Note that the two headrest clips can be put back last.
                  Remember to line up all holes
                  Seat back together.
                  The whole job only took an hour so isnt hard
                    I was going to put these on but they are from a Maestro and don't have the back pocket. They look brand new with no tears and with a bright red stripe and MG logo and include the bases. I also have the rear seat covers available. Does anyone want to make a sensible offer for the set?
                      Hi,
                      Would be interested it the set, as mine in my Turbo are showing some wear!
                      If would PM me with details?
                      many thanks
                      Jamie
                      MGT172
                      Jamie
                      MG Maestro Turbo No. 172
                      Land Rover Defender 50th No. GB093
                      Jaguar XJR100
                      Mercedes Vito 122 SportX
                      Ford Sierra Sapphire Cosworth 4x4
                      Audi 80 B2 Quattro 2.2
                        Nice tutorial Jeff, thanks for taking the time to do it.
                          Covers now sold. Thanks
                            Great article and good of you to share it with us all.
                            Thats the beauty of forums such as this.
                            Well done Jeff.
                              Brilliant. And just the kind of thing we like people to send us for Monstro
                              Jonathan Sellars
                              1987 MG Maestro 2.0 EFi
                              2011 Jaguar XJ
