Old 21st February 2009, 20:15   #1
henocsr
Default Black trim
What does ever body else use to recolour black plastic trim on their maestros/ montegos. I have been using autoglym rubber and vinal cleaned, which i have always used on my other Rovers buit the efis bumpers were the red inserts are, are nearly white so its no good.
I hope i dont have to respray them
2001 Rover 45 1.8 impression s saloon
1997 Rover 623 GSI auto
henocsr is offline   Reply With Quote
Old 21st February 2009, 21:07   #2
G51 NAV
Temporarily bedridden
G51 NAV's Avatar
Send a message via MSN to G51 NAV
I can list you any number of products which will do a good temporary job if you want your car to look good at a show, the simplest of which is actually black shoe polish. But if you want the black to actually stay black, respraying is the only permanent solution. Not just bumper strips, this also goes for door-mirror surrounds and models which have the unpainted black bodykit.
Spraying them is not the hard job: after a practise you'll find that any monkey can get a satisfactory job spraying rough plastic with thin coats of satin-black paint. It's not like you're trying to get an even, highly reflective shine. With the bumpers, it's masking-off which is a PITA, in so far as it's fiddly and time-consuming.
I rang up Domino's Pizza last night and ordered a Thin 'n' Crusty Supreme. They sent me Diana Ross!
G51 NAV is online now   Reply With Quote
Old 21st February 2009, 21:32   #3
henocsr
cheers, i will have to spray then. Mine has the black body kit too
Old 21st February 2009, 21:38   #4
G51 NAV
G51 NAV's Avatar
You won't regret painting them. It does make a lot of difference as a finishing-touch to a car which looks otherwise cosmetically tidy.
Old 21st February 2009, 21:38   #5
MaestroTurbo
Try a heat gun.... but the black 'inserts' turn white and there is very little you can do to improve things apart from paint them black again. The plastic isnt porous enough to absorb any chemical.
MaestroTurbo is offline   Reply With Quote
Old 23rd February 2009, 00:22   #6
wee_dav
wee_dav's Avatar
A guy in my work (who used to build montegos in cowley) told me about a chemical he used in the past but cant remember the name of it. he said its like a dye or stain which makes them pure black again. I will ask him again what its called. Sounds good but maybe the plastic isn't pourus enough to absorb. I'd love to redo the plastic on the tops of my doors. auto glym works but only for a day.
wee_dav is offline   Reply With Quote
Old 23rd February 2009, 08:36   #7
G51 NAV
G51 NAV's Avatar
That will probably help on everything but the bumpers. The polycarbonate is not porous enough.
Old 23rd February 2009, 09:31   #8
Jumturbo
Jumturbo's Avatar
I think you are talking about the natural plastic finish which was moulded in black and not painted at all at the factory? As we know all plastic moulded products will fade in sunlight. Under the surface however the coloured plastic should be unaffected. You somehow need to remove the top surface. Try a foam rubbing compound - the sort you use on new paint. Or Maybe T-cut and plenty of elbow grease! Best to try this before you go to trouble of painting etc. Another thing to try is a product used for cleaning PVC window frames. We cleaned our frames last year with this stuff with amazing results. The ground in grime was easily removed. It was a kind of thinners based chemical, probably find it on line if you search for PVC window frame cleaner. Watch any painted surfaces though!
'56' MG ZTT160 Silver
'05' MG ZR115TDSE Red (Hers)
'W' TR7V8 Will be Black
Jumturbo is offline   Reply With Quote
Old 26th February 2009, 12:18   #9
Simon
Simon's Avatar
Vinylkote?
Simon is offline   Reply With Quote
Old 26th February 2009, 17:35   #10
John S
John S's Avatar
Carplan liquid wax is good for black plastics I find.
1989 MG Maestro Turbo no.399
In hibernation. Now with full leather. 113,000 miles
1994 Maestro Clubman Turbo Diesel
Stored. 112,000 miles
John S is offline   Reply With Quote
