maestro rebuilding
  • maestro rebuilding
    Does anyone know where I can get a set of both sides rear arch replacement panels for a maestro turbo? ?
    Gonna bite the bullet and replace both know there's going to be no trouble later then
    Cheers
    Andy
    oop think there should be some metal here
    http://
      I bought that panel from Rimmer Bros, it arrived today. about £12.
      http://www.rimmerbros.co.uk/Item--i-BEP1012
      BUT, having just looked closely at the picture I've bought a metal bumper one. ARSE. BUT, I'm assuming that I can make it fit without too much bother.
      Ian
      Ian Drew
        I've just been.looking at that. Might order one and if no good will cut my own out on the laser to suit.
        Hardest nit of this rebuild jobby is finding original panels they are like rocking horse poo arrgghj
        Think a lot is going to be custom made to suit
          Made a bit of progress today. Turns out boot floor had gone about and inch back and both boot panels inner and outer
          Cut out the floor and welded in a strengthening angle and made up a complete boot panel Inc lip to pick up boot floor
          All welded up and just need couple of mounting holes drill and inner boot panel Needs bit if tweaking and fully welding
          bit of tiger seal to neaten up and good few coats of primer needed now
          arch and sills next
            A lot of good work going on there - decent mig welder too. Nice job - keep up the good work - I'll be watching this restoration thread with great interest.
              It's slow progress as it's random places the rust has took hold and trying to make new pieces out of zintec to at least give that bit extra protection
              Hoping this weekend to remove rear beam and strip and send off for powder coating and totally rust eater and rust proof the back underside
              Hoping for a completion this time next year
                Coming on well that, keep up the good work.
                I have arch panels coming in a couple of weeks, they are the metal bumper type but can be modified if been informed.
                I also have Maestro sills being delivered so if you want any let me know.
                  Today's mission remake a panel for the inside of the boot
                  Been a right pig but couple of 50mm holes to do and bit of paint to tidy up
                  Least I know the boot is actually solid now
                    Good work!
